GWS Tool Group
High-Feed Cutters Improve Tool Life
Ingersoll Cutting Tools will show its Hi-QuadF line of high-feed cutters.
Ingersoll Cutting Tools will show its Hi-QuadF line of high-feed cutters. The cutters are available with a 13-mm and a 19-mm IC quad-style insert, which provides four cutting edges with a choice of eight different cutting edge geometries. The maximum depth of cut ranges from 0.088" for the 13-mm IC insert to 0.145" for the 19-mm IC insert.
According to the company, the insert grades coupled with edge preparations ensure long tool life, even with demanding applications across a range of materials. A positive axial insert orientation creates a high-shear, free-cutting nature for the Hi-QuadF cutters. Chip thinning is leveraged to a factor of 5× when calculating feed rates. A robust insert screw design secures the insert in the pocket, ensuring cutter performance and insert seating stability.
  • How to Mitigate Chatter to Boost Machining Rates
  • Tungaloy Expands Line of Barrel-Shaped End Mills
  • A New Milling 101: Milling Forces and Formulas
Sumitomo
SGS
Horn USA
IMCO
GWS Tool Group
