High-Feed Face Mill Boosts Productivity
The Gold-QuadXXX high-feed face mill from Ingersoll Cutting Tools features a positive 30-degree bevel angle along with increased depth of cut provided by ultra-strong, free-cutting insert geometry, resulting in increased productivity.
The Gold-QuadXXX high-feed face mill from Ingersoll Cutting Tools features a positive 30-degree bevel angle along with increased depth of cut provided by ultra-strong, free-cutting insert geometry, resulting in increased productivity. Two insert sizes, seven different geometry options and four indexes are available.
