High-Feed Milling Cutter Provides High Stability for Improved Feed Capacity
Sandvik Coromant’s CoroMill 415 high-feed milling cutter for diameters ranging from 13 to 25 mm (0.5" to 1") provides enhanced security with the iLock insert seat interface and high metal removal rates thanks to high cutter density and feed capacity.
The iLock insert seat interface is designed to deliver high stability and reduce the potential for scrapping the workpiece. The insert seat itself ensures that the small inserts are easier to handle, the company says. The cutter density and feed capacity are supplemented by the cutter’s extra-close H pitch, which can be deployed thanks to the tool’s inherently high stability, ensuring more than one tooth is always engaged in the cut. Each of the inserts offers four cutting edges.
The CoroMill 415 is also available with the Coromant EH (Exchangeable Head) interface, which the company says enables shops to reduce their tooling inventory and minimize machine downtime.
10 Tips for Titanium
Grooving Attachment Streamlines Operation by 75%
A grooving attachment enabled Keselowski Advanced Manufacturing to reduce cycle times by over 45 minutes on a high-value, high-nickel part feature.
