High-Feed Quad Cutters for Milling
Ingersoll’s Hi-QuadF high-feed milling cutters are available with a 13-mm IC insert for 0.088" depth of cut or a 19-mm IC insert for 0.145" depth of cut.
Ingersoll’s Hi-QuadF high-feed milling cutters are available with a 13-mm IC insert for 0.088" depth of cut or a 19-mm IC insert for 0.145" depth of cut. The inserts offer four cutting edges and a choice of eight different cutting edge geometries. The positive axial insert orientation is said to create a high-sheer, free-cutting nature. Chip thinning is leveraged to a factor of 5× when calculating feed rates. Cutter performance and insert seating stability are ensured with an insert screw design that secures the insert in the pocket.
10 Tips for Titanium
Widia Introduces Solid End Mill for Shoulder and Side Milling
