High-Penetration Insert Designed for Structural Steel
Allied Machine & Engineering has released an addition to the Gen3sys XT Pro line of high-penetration inserts. designed for the structural-steel market.
Allied Machine & Engineering has released an addition to the Gen3sys XT Pro line of high-penetration inserts designed specifically for beam and plate production in the structural-steel market. With a combination of substrate and multilayer coating, the insert is engineered to withstand heat generated while drilling in structural-steel beams or plates in high-production facilities. Optimized in their existing structural steel holders, Allied’s high-tech structural steel insert is said to improve chip formation and reduce vibrations, creating a higher-quality hole.
The composition of its carbide grade, geometry and high-temperature coating are designed to run at or beyond current rates from original equipment manufacturers while offering extended tool life. The insert’s simplified setup and extended tool life reduces change-over and increases throughput. The company says the insert is designed to improve run rates, reduce tool failures and increase capacity.
IMCO
Iscar
SGS
Ingersoll Cutting Tools
Horn USA
GWS Tool Group
IMCO
