High-Performance Tap
The MultiTAP is designed to cut a range of materials including carbon steel, steel alloys, stainless steel, aluminum, cast iron, copper, brass and bronze.
New Product From: 6/18/2010 Modern Machine Shop
The MultiTAP is designed to cut a range of materials including carbon steel, steel alloys, stainless steel, aluminum, cast iron, copper, brass and bronze. The tap is designed to produce threads within both 2B and 3B classes of fit.
The tap is constructed of a grade of high speed steel (HSS-E), Nitrided with a Ne2 surface treatment. It is available in both spiral point and spiral flute configurations for through- or blind-hole applications. Tap sizes cover a full range for UNC or UNF threads, from #4-40 to ¾"-16" in inch sizes, to metric sizes from M4 × 0.7 to M16 × 2.0.
According to the company, the tap is designed for a job shop or a manufacturer that works with short- and medium-run threading applications across a spectrum of materials.
Register Now for IMTS 2012
More technology – a lot more!
Learn More about IMTS 2012
Emuge Corp.
MMS Zones
Emuge Corp.
Zones
Supplier Categories
ERIX tool saves up to 90% of the manufacturing time on back spotfacing and chamfering operations.
Learn more on tooling suppliers in the Tooling Resource Center.
Premium tooling and technology for high-quality, precision machining.
