High Pressure Coolant Systems Designed for CNC Machine Tools
MP Systems offers the V2 general-purpose, compact, high-pressure coolant system and the S2 combined high-pressure coolant and chiller system.
New Product From: 8/10/2012 Modern Machine Shop
MP Systems offers the V2 general-purpose, compact, high-pressure coolant system and the S2 combined high-pressure coolant and chiller system. The coolant systems can accommodate two to 12 lines with a remote manifold block that also reduces hose clutter. According to the company, the clean, streamlined design includes on-board feed pumps that can be used for oil- and water-based coolant.
The V2 houses all of its internal components within a high-quality, sheet-metal frame designed to fit under a standard-height bar feeder, the company says. Premium casters ease relocation of the pump on the shop floor. A heat exchanger is available as an option.
The S2 system can run oil-based coolant at 2,000 psi at a rate of 5 gpm and water-based coolant at 1,000 psi at a rate of 8 gpm. A PLC provides real-time monitoring. It uses air, reservoir and outgoing-coolant temperatures sensed by monitoring gages to adjust performance and automatically compensate for changes in ambient temperature and coolant temperature. Standard features include a seven-day timer clock and automatic shut-off system.
The company will also display its RF8 reservoir high-pressure coolant system for CNC machine tools and its RT twin-pump model for large, twin-turret lathes.
Register Now for IMTS 2012
More technology – a lot more!
Learn More about IMTS 2012
MP Systems
MMS Zones
MP Systems
Zones
