High Speed Grinding Machine with Generation Control
The Junker Company will display its Lean Selection speed, a high speed grinding machine.
New Product From: 8/7/2012 Modern Machine Shop
The Junker Company will display its Lean Selection speed, a high speed grinding machine. The machine is now available with a generation control system. It can be used with both CBN and diamond abrasives on small batches or in mass production. The machine is equipped with a high-resolution B axis, making it suitable for a range of applications. It is capable of grinding ODs, shoulders, chamfers, radial grooves and plunge cuts. Rough- and finish-grinding operations can be done using up to two high speed grinding spindles with 12-kW drive power and a peripheral speed ranging to 140 m/sec. to maximize stock-removal rates and provide quality surface finishes.
Other machines on display include the Lean Selection allround multifunctional grinding machine; Grindstar grinding machine; Quickpoint high-capacity grinding machine; Platemat peripheral grinding machine; Jupiter centerless grinding machine; Jucrank pendulum grinding machine; Jucenter machine concept with two grinding stations; Jucam non-circular grinding machine; and Jumat OD/ID grinding machine.
Register Now for IMTS 2012
More technology – a lot more!
Learn More about IMTS 2012
Junker Machinery, Inc., Erwin
MMS Zones
Zones
