High-Speed Graphite Mill Features Temperature Compensation
GF Machining Solutions’ high-speed Mikron Mill S 400/500 Graphite and Mikron HSM 500 Graphite are dedicated specifically to graphite machining.
GF Machining Solutions’ high-speed Mikron Mill S 400/500 Graphite and Mikron HSM 500 Graphite are dedicated specifically to graphite machining. Graphite glass molds for glass end products are especially common in markets such as information and communications technology (ICT), while graphite electrodes are typically used in the automotive, electronic components, aerospace and packaging sectors. These two machines are designed to mee the peculiar challenges of machining graphite in these contexts.
The three-axis Mill S 400/500 Graphite is said to resolve the challenges of machining graphite molds. As ambient workshop temperatures fluctuate and machining speed changes, process stability is maintained thanks to an intelligent thermal management system and thermostabilized machine body. Precision and stability at the tool tip are said to be insured by the Step-Tec HVC140 spindle, with speeds ranging to 42,000 rpm and 13.5 kW of power.
Besides long-term precision in graphite, the machine can also handle a range of materials in a clean environment.
The Mikron HSM 500 Graphite suits dry machining with a well-established process, a simple and compact design, and no graphite slurry accumulation, according to the company. The machine’s Step-Tec HVC140 spindle, integrated dust extraction and integrated System 3R WorkPartner (WPT1+) part-changing robot combine to enable automated machining of small graphite electrodes.Related Content
Vertical Lathe Executes Heavy-Duty, Long and Continuous Cutting
New VT1000EX Vertical Lathe from Okuma America Corp. possesses the capability to cut and machine difficult materials through, according to Okuma, its highly rigid, mechanical configuration, extreme thrust and torque.
