High-Speed Milling of Small, Complex Parts
GF AgieCharmilles' Mikron HSM 200U LP (linear performance) milling machine is said to increase speed, efficiency, precision.
GF AgieCharmilles' Mikron HSM 200U LP (linear performance) milling machine is said to increase speed, efficiency, precision. The machine enables true 5-axis simultaneous milling for machining small, highly complex components. Linear motor technology in the main machine axes and optimized direct-drive motors for the B and C axes provide high precision and part surface finishes as fine as Ra 0.05 µm. The 50,000-rpm, 11.4-hp Step-Tec spindle also helps to improe surface finish and part detail.
Okuma
High Accuracy Linear Encoders
Okuma
