High Speed Mills Feature Motion-Control System
Hurco will showcase its VMXHSi high speed mills equipped with direct-drive servos.
Hurco will showcase its VMXHSi high speed mills equipped with direct-drive servos. The VMX24HSi and VMX42HSi feature Hurco’s Ultimotion motion-control system, said to reduce machine jerk while improving surface-finish quality. An integral spindle features an 18,000-rpm base speed spindle and is equipped with ABEC-7 ceramic hybrid bearings to manage thermal issues associated with high speed milling (HSM), the company says. Air-over-oil spindle lubrication distributes oil evenly to the bearing. An automatic toolchanger with HSK tooling is said to provide a chip-to-chip time of 4.5 sec.
Larger linear rails are mounted to a machined shoulder for increased rigidity and wedge-locked to the frame to reduce vibration. Pre-loaded and stretched ballscrews are anchored at both ends. The Hurco integrated control is optimized for HSM with a 64-GB solid-state drive, 2 GB of memory, a 2-GHz dual-core Intel processer, processing speed ranging to 2,277 bps and dynamic variable look-ahead with capacity of 10,000 blocks.
What to Do When Five-Axis Machining Is Off the Table
For Fischer USA, 3+2 machining with a high-precision rotary table adds flexibility without the cost of a full five-axis machine.
SMEC America Showcasing Machines' Reliability and Rigidity
SMEC America is running demonstrations on its machines both old and new at its IMTS booth, with engineers on hand to help answer questions.
