Multi-axis machining with Fusion
High Speed Roughing Strategy Removes More Material
Esprit 2013, available from DP Technology, features the ProfitMilling strategy for two-, three-, four- and five-axis roughing cycles.
Esprit 2013, available from DP Technology, features the ProfitMilling strategy for two-, three-, four- and five-axis roughing cycles. The high speed roughing cycle enables deeper cuts at increased cutting feeds to remove more material in a shorter amount of time, the company says. The strategy monitors several cutting and machine characteristics rather than controlling just one parameter. Chip load and side-cutter force are managed in toolpath calculation while keeping the engagement angle and material removal rate within a specific range. The strategy also incorporates feedrate changes throughout the tool path and takes advantage of toolpath optimization for specific machine capabilities.
SmartCAM
HCL CAMWorks 2024
Surface finishing in Fusion
Siemens Zel X
Siemens Zel X
