HMC Promotes Higher Throughput per Spindle
IMTS 2018:
FFG MAG is debuting its MMH 500 horizontal machining center for the general market, designed with precision, power, performance and productivity in mind. All MMH machines come with linear axis speeds of 60 m/min. and a 12,000-rpm direct-drive spindle (optional 15,000 rpm) which results in more machine throughput per spindle and high-speed cutting capabilities. The high-pressure coolant-through tool/spindle-ready feature provides flexibility to application changes with the ability to apply 1,000 psi at a small upgrade cost. The large tool capacity enables more application possibilities on one machine.
The MAG MMH 500’s standard infinite contouring B-axis table delivers higher precision part cutting without having to add this typically-expensive option. The machine is prepared for 480-V connection, requiring no isolation transformers, saving users valuable floor space and investment cost, according to the company. Unlike many other horizontal machining centers in the market, MAG’s MMH 500 is designed and built with North American Controls Design and Safety Standards, which fully conforms to the latest U.S., Canadian and Mexican safety standards.Related Content
Horizontal High-Speed Machining Saves Hundreds of Work Hours
High-speed machining is the latest change at Blair-HSM South, helping this once old-fashioned shop improve productivity and morale while enabling new work.
Translating a Prototyping Mindset to Production
The experimental mindset that benefited BDE Manufacturing Technologies as a prototype job shop has given it an adaptable edge as a production facility.
Shop Replaces Two Verticals With One Horizontal
By trading two VMCs in to help finance the purchase of a new HMC, this shop was able to significantly increase production and move to lights-out machining.
