HMC with W Axis Cuts Exotic Materials
Sponsored Content – IMTS 2016 Technology eNewsletter
The hallmark of the MA-12500H-W is its ability to provide a good balance of speed and cutting power for machining difficult-to-machine materials, cast iron and aluminum alloys. This makes it well-suited for large-part aerospace machining. The W axis allows for a longer tool stroke to machine complex, difficult-to-reach part features. It has a maximum tool length of 1,100 mm. At IMTS 2016, the MA-12500H-W will be shown with the new W-axis option and in skeleton form. It will feature a cutting simulation of a steel construction frame.
Key Features of Okuma’s MA-12500H-W Horizontal Machining Center
Built on an integral bed and base and designed with reinforcing ribs for increased stability and load carrying capacity, the MA-12500H incorporates Okuma’s exclusive Thermo-Friendly Concept to achieve maximum thermal stability and accuracy. Standardly-equipped with a 50-taper, 6,000-rpm, 60/50-hp spindle, it is also available with either a 12,000-rpm wide-range spindle or 4,500-rpm heavy-duty spindle.
Maximum load capacity of 11,000 lbs
Rapid traverse (X, Y, Z) of 1,653 ipm
Maximum part size: 78.72" diameter × 58.07" high
Axis travels—X: 86.61"; Y: 58.07"; Z: 64.96"
0.001-degree B-axis rotary table
49.21" square pallet
Parallel-type two-pallet APC
81-tool matrix ATC standard, up to 171-tool matrix optional
Visit the company's IMTS showroom for more information.
Can Machining Simulation Propel Machining Education?
Digital twins prove their worth for not only proving out CNC programs, but also training the next generation of programmers.
Beards of IMTS - Amazing Feats of Beard Engineering
Manufacturing has a multi-talented bunch of people, but who knew so many were adept in the facial hair industry? Check out the best of the beards at IMTS!
NASA Brings Technology to New Heights
Meet NASA mission system engineer Mike Menzel and learn more about the James Webb Space Telescope at Mitsui Seiki USA’s booth (338700) in the South Hall from 11:00 a.m. to 11:45 a.m. on Thursday, September 15.
