HMCs Machine High-Temperature Resistant Steel
Chiron’s 26 series horizontal machining centers are designed for large workpieces such as gear housings, structural parts or components made up of high-temperature-resistant steel.
Chiron’s 26 series horizontal machining centers are designed for large workpieces such as gear housings, structural parts or components made up of high-temperature-resistant steel. The series offers machines with bridge dimensions ranging from 1,250 to 3,000 mm, with Y and Z axis travels measuring 630 mm each. The single-spindle version can be equipped with a swivel head, while the double-spindle design offers spindle distances of 600 or 900 mm.
The machining centers provide torque ranging to 390 Nm and spindle speeds as high as 10,000 rpm for high cutting performance in cast iron and steel parts. An HSK-A 63 tool taper version with spindle speeds ranging to 16,000 rpm is also available. The series is suitable for aluminum structural parts such as those required in the automotive and aerospace industries. A rotary table program is available for five-axis applications.
Digital Demo: X-Series CNC Machine for Extrusions
This unique fixturing system provides maximum hold with minimal clamping footprint to optimize spindle clearance and allow chips, debris and cutoffs to drop below the machining area and away from the spindle. (Sponsored)
The Job Shop Is the First Half of the Business
By day, NTL Industries went from a lathe and a mill in a home garage to an 11-employee enterprise in under five years. By night, it tackles a new future.
The Debut of an HMC Series
The FH5000 Series from JTEKT Toyoda is compromised of three high-speed horizontal machining centers.
