Horizontal Turning Center Handles Parts as Long as 118 Inches
SMTCL’s EHC 125300 horizontal turning center enables the production of large workpieces.
SMTCL’s EHC 125300 horizontal turning center enables the production of large workpieces. Designed for high precision, the turning center has a swing over the bed of 1,250 mm (49") and can machine parts as long as 3 m (118"). It comes standard with a 1,000-mm chuck, eight-position turret, steady rest, hydraulic tailstock and chip conveyor.
The turning center uses a FANUC motor and 0i-TF control, THK ballscrews, NSK spindle bearings, a Stober gearbox, and a Sauter turret. The company offers installation and training services to customers anywhere in North America.
The company is also releasing the EHC 125500, which can machine workpieces as long as 5 m (196") and weighing as much as 11,000 lbs.
