Hydraulic Collet Clamping System for Tight-Tolerance Applications
The hydraulic clamping 5C collet system incorporates multiple-part workholding with fast, efficient clamping to maximize spindle cut time and density of parts.
The hydraulic clamping 5C collet system from Paws Workholding incorporates multiple-part workholding with fast, efficient clamping to maximize spindle cut time and density of parts. The system is available in two sizes: a 12" × 16", 24-station version and an 8" × 10", eight-station version. It is particularly suited for OD gripping when tight tolerances, rigidity and part repeatability are critical.
Machining Vektek Hydraulic Swing Clamp Bodies Using Royal Products Collet Fixtures
A study in repeatable and flexible workholding by one OEM for another.
