| Home | Article Archive | Latest Issue | Talk To Us | Previous Page (or Use Back Button) |
| Online Tools & Calculators | MMS E-mail Newsletter |
MMS inMotion Multimedia Presentation - ROI: Machining Cells and Management Systems
What Is an palletized operation system? - Transcript
(Select the link below to access the entire presentation.)
Learn More. MMS Online.
MMS inMotion - Multimedia Metalworking Mojo
Watch ROI: Machining Cells and Management Systems
This MMS inMotion presentation from Makino explains how Error-proofing your process can maximize throughput and speed up your entire operation.
For More Information
MMS Direct - Get Company Info Here ...visit Makino's MMS Online Showroom, or select the MMS Direct icon at right.
online tools
Link a Friend to This Page Via E-mail
print article Print this article
So what exactly is a Makino MMC? It’s a palletized automation system. It will take a part from a work-setting station, where a raw part would be loaded, for example, and move that part to an available machine or to a pallet storage system to await an available machine. On the other side, it will take a finished part from a machine and place it for extraction. In either case, the system does offer a pallet storage system for raw or finished parts. The system requires an upper-level software to manage and schedule parts for production. One of the key elements, our customers tell us, is that once you get a job set up and running, it stays resident in the cell controller software. What that means is, once the data is entered, the software keeps everything in memory so the next time you need to run the part, you just call up the file and run it. Scheduling of work is another key element of the system, allowing you to schedule short jobs to run during the work shifts and longer jobs during shifts where labor is not present, allowing your people to return to finished points and increase your ability to produce more at a faster rate.
MMS Online is a trademark of Gardner Publications, Inc, copyright 1997-2008.
MMS Online and all contents are properties of Gardner Publications, Inc.
All Rights Reserved.
