| Home | Article Archive | Latest Issue | Talk To Us | Previous Page (or Use Back Button) |
| Online Tools & Calculators | MMS E-mail Newsletter |
MMS inMotion Multimedia Presentation - Automated 5-Axis Machining
Business Issues - Transcript
Learn More. MMS Online.
View this multi-media presentation
This multimedia presentation Makino demonstrates weldless molding capabilities only possible with new, cutting edge technologies and techniques.
View All Presentation Transcripts
For More Information
MMS Direct - Get Company Info Here ...visit Makino's MMS Online Showroom, or select the MMS Direct icon at right.
online tools
Link a Friend to This Page Via E-mail
print article Print this article
The business issues here include cutting lead-times. In many cases, we’ve seen people who automate a 5-axis system and cut their lead-times in half. The ability to easily run low volumes is really a big part of this.
You can significantly reduce WIP and finished goods inventory, mostly because you can do the parts in fewer operations and not have parts sit between operations.
Increased equipment utilization has a huge impact on the manufacturing capacity of a single machine. Minimizing direct and indirect labor is a concept typically operated by a single person, which means you can increase output without increasing labor.
You can eliminate setup simply because the machine is always producing while you’re setting up, which means the machine doesn’t wait on setup.
Flexibility: we mentioned large and small lots. With the 5-axis capability, you’re handling parts less often, leading to reduced stack-up errors, which will also improve quality and part-to-part consistency.
With that, I’d like to show this video. What you’re going to see is a manufacturing process that includes an actual case study. This particular company is a high-level job shop, meaning that they do a lot of complex parts, which is one reason they went with the 5-axis setup. So they had a need for automation to increase the spindle utilization.
The application is an aerospace-type part, an airframe. And you’ll see the part as we run this video. Please sit back and enjoy this video.
MMS Online is a trademark of Gardner Publications, Inc, copyright 1997-2008.
MMS Online and all contents are properties of Gardner Publications, Inc.
All Rights Reserved.
