Improved Capacity on Five-Axis Machining Center
The C 42 U machining center was designed to increase capacity in the company’s machining range.
New Product From: 8/6/2010 Modern Machine Shop
According to the company, the C 42 U machining center was designed for increased high-precision, five-axis performance in rugged alloys and other materials for industries including moldmaking, medical, aerospace and others.
Utilizing the company’s patented modified gantry design, the machining center is available with a mineral-cast base to damp vibration and minimize thermal conductivity. The X, Y and Z axes measure 800 × 800 × 550 mm, respectively, with rapid traverse rates of 60 m/min. in all axes. The spindle features a slim-end design for deep-cavity machining and is available in speeds of 10,000, 18,000 and 25,000 rpm. The two-part spindle design incorporates six displacement sleeves for collision protection.
Tool change is accomplished by direct pick-up, and the magazine accommodates 42 tools. Maximum tool length is 300 mm and diameter is 90 mm. Tooling is SK 40 and HSK A 63 (the 25,000-rpm spindle utilizes only HSK A 63). Chip-to-chip time is approximately 4.5 sec. Tooling can be expanded to 160 pockets.
The machining center is available with a variety of table configurations for multiple applications. For three- and four-axis machining, a rigid clamping table with a 1,050- × 805-mm surface and a load capacity of 2,000 kg is available. Five-axis versions incorporate swiveling rotary tables in three sizes: 800 × 630 mm with a maximum load of 1,400 kg; 440 mm with a capacity of 450 kg; and 420 mm with a 600 kg load capacity.
The compact design and integrated tool magazine simplify installation and provide a large, easily accessible work area, the company says. The machine is available with the Heidenhain iTNC 530 or Siemens 840 D SL CNC, as well as various options for coolant application, chip control, tool management and more.
Hermle Machine Company LLC
MMS Zones
KOMA Precision, the finest the world has to offer in machine tool Productivity Innovation.
