In-Line Magnetic Separators for Coolants and Cutting Oils
Keller Products’ magnetic separators for machine tool coolants and cutting oils feature a magnetic rod assembly that fits standard 10" cartridge filter housings.
Rego-Fix Toolholding System Reduces Coolant Consumption
Henkel Redefines Industrial Machining and Grinding with Sustainable Metalworking Innovation
With innovative formulation and bio-resistant properties, Henkel’s new semi-synthetic lubricant emerges as a pioneering solution in the machining industry.
STLE Opens Registration for 2024 Annual Meeting
The Society of Tribologists and Lubrication Engineers’ 2024 STLE Annual Meeting & Exhibition will take place May 19-23 at the Minneapolis Convention Center in Minneapolis, Minnesota.
