Indexable Insert Sharpening Process Uses Selective Grinding
R & J Tool’s indexable carbide and ceramic insert sharpening process sharpens inserts by selectively grinding material to produce a new cutting edge.
New Product From: 7/3/2012 Modern Machine Shop
R & J Tool’s indexable carbide and ceramic insert sharpening process sharpens inserts by selectively grinding material to produce a new cutting edge. According to the company, this is not downsizing—the inscribed circle is not reduced and the locating surfaces are not changed. Instead, the sharpening process takes specific customer applications into account with geometries, edge preps and coating combinations that enable the same or improved performance as a new insert, the company says. The process is available on carbide and ceramic inserts for both milling and turning applications.
A plunge grind geometry and a ground wiper will be two of the developments on display along with examples of sharpened milling and turning inserts, new and sharpened small-hole tooling, sharpened indexable drill tips, and the Tip-Lok top-clamp milling cutter.
Register Now for IMTS 2012
More technology – a lot more!
Learn More about IMTS 2012
R & J Tool, Inc.
MMS Zones
R & J Tool, Inc.
Zones
