Indexing/Tilting Table for Complex EDM Work
The H100ABR.NC is a submersible, stainless steel two-axis tilting and dividing table used for complex wire, vertical and small-hole EDM applications.
New Product From: 6/15/2010 Modern Machine Shop
The H100ABR.NC is a submersible, stainless steel two-axis tilting and dividing table used for complex wire, vertical and small-hole EDM applications. These applications include medical, power turbine, aeronautical engineering, gear manufacturing, R & D and others.
The device is equipped with a 100-mm-diameter face plate with mounting holes for fixtures and the company’s manual clamps. Optional integrated air connections for pneumatic clamps are available. The A and B axes are programmed and driven by the H1625.AC2 controller, which enables automatic sequencing by M code to the machine’s control. The NC program is generated via the keyboard or by downloading from a PC or machine control by using an RS232-interface. The company plans to offer direct integration with select machine tools eliminating the need for the H1625.AC2 controller.
Hirschmann Engineering USA Inc.
MMS Zones
Zones
Supplier Categories
