Insert Drills Cut Varied Materials
 KUB Pentron line of drills provides length-to-diameter ratios of 5 × D. The system is equipped with two square inserts that have four effective cutting edges each. The internal and external inserts have exactly the same shape.
New Product From: 4/10/2009 Modern Machine Shop
 KUB Pentron line of drills provides length-to-diameter ratios of 5 × D. The system is equipped with two square inserts that have four effective cutting edges each. The internal and external inserts have exactly the same shape. From all-round geometry to soft cutting and what is known as chip breaker geometry, inserts with high performance substrates and coatings are available for a variety of materials.
KOMET of America, Inc.
MMS Zones
Zones
Supplier Categories
Premium tooling and technology for high-quality, precision machining.
ERIX tool saves up to 90% of the manufacturing time on back spotfacing and chamfering operations.
Standard grooving tools from .004" in .001" increments with any corner radius. We stock more than 100,000 tools!
Learn more on tooling suppliers in the Tooling Resource Center.
Loading the player ...
