Insert Geometry Designed for Targeted Cooling
Walter's FM5 finishing and RM5 roughing indexable insert geometries are designed to deliver optimal cooling, longer tool life, and increased productivity in high-temperature alloy and stainless-steel machining.
Walter's FM5 finishing and RM5 roughing indexable insert geometries are designed to deliver optimal cooling, longer tool life, and increased productivity in high-temperature alloy and stainless-steel machining. The inserts feature “jet guiding geometry,” or targeted cooling. Channels pressed in the rake face enable coolant to reach the cutting edge directly, underneath the chip, to maximize the cooling effect, increase tool life and optimize chip breaking for increased productivity and improved workpiece surfaces.
Three insert grades (WSM10S, WSM20S and WSM30S) feature PVD Al2O3 heat shield, and one (WMP20S) features CVD. All grades also have the company’s Tiger-tec Silver coating for maximum tool life.
The inserts’ double positive macro-geometry reduces notch formation and crater wear. Both the RM5 and FM5 geometries were designed to work with the coolant channel geometries of the company’s toolholders, but can also be used with standard ISO turning toolholders.
Best Practices: Machining Difficult Materials
10 Tips for Titanium
Buying a Lathe: The Basics
