Integrated CAM System for a Range of Applications
The newest addition to the company’s range of CAM solutions is Delcam for SolidWorks, which is said to extend the company’s ability to offer a CAM system to machine a range of materials and components on equipment such as simple lathes and mills to complex five-axis and turn-mill machines.
New Product From: 4/5/2011 Modern Machine Shop
The 2011 version of PowerMill is said to make the programming of safe tool paths easier with new stock-model-engagement options that protect both the cutting tool and the machine from excessive loading. Other enhancements include new editing capabilities to simplify the machining of duplicate items; more versatile control of feed rates for leads and links; and extra functionality for sketching.
FeatureCAM 2011 incorporates support for 64-bit computers, improved data exchange from a wider range of design software, the ability to use stock models and new strategies from turning to five-axis machining. The new release also has a more modern interface to simplify programming.
PartMaker 2011 include more powerful milling functionality; a more flexible tooling library; improved programming and simulation of bar-fed mills; more detailed mid-process documentation; and additional productivity enhancements. In addition, multi-axis milling functionality continues to be added.
Delcam
MMS Zones
Delcam
Zones
Supplier Categories
• 2-5 Axis Milling
SmartCAM V18.5 features New Mill/Turn Sub-Spindle and B-axis Support, Morph Pattern Roughing.
Get the Edge with iMachining - the revolution in CNC Machining. Time savings up to 70%!
Increase your productivity and bottom line with SURFCAM!
www.surfcam.com
HSMXpress is full
featured 2 1/2-axis
CAM for SolidWorks.
Best of all, HSMXpress
is absolutely FREE!
Loading the player ...
