Integrated Electrode Solution for EDM
Delcam will showcase its Electrode, a complete solution for design, machining and inspection of EDM electrodes.
Delcam will showcase its Electrode, a complete solution for design, machining and inspection of EDM electrodes. The program combines Delcam’s PowerShape CAD software, PowerMill CAM system and PowerInspect inspection software. Electrode uses the new .Trode file format which contains all the information for each electrode project, including the electrode design, machining and inspection information, and set-up sheets for its manufacture and use. The format is designed to simplify data management and increase overall efficiency by packaging all the required information into a single file.
The company will also highlight its scripts for automating the programming of EDMs.
Improve Machining Efficiency Through Digital Twin Simulation
Full simulation of a machining cycle using digital twins can not only identify crashes before they happen, but provide insights that enable the user to reduce cycle times.
TTI Brings Specialty Gear Production In-House with Multiaxis Machining
By investing in a 3+2-axis machine and utilizing simulation software for diagnostic checks, Techtronic Industries turned a four- to ten-week lead time into a one- to two-week lead time.
