Laser Alignment Tool for CNC Gantry Machines
Pinpoint Laser Systems offers its Pinpoint Gantry Kit, a tool for geometric alignment of three-axis CNC gantry machines.
New Product From: 8/25/2014 Modern Machine Shop, ,
Pinpoint Laser Systems offers its Pinpoint Gantry Kit, a tool for geometric alignment of three-axis CNC gantry machines. Its straight, weightless laser beam replaces traditional piano wire, heavy steel straight edge and granite references. The company says that its tool is faster, easier and more consistently accurate than conventional methods, checking an entire machine in hours. Other potential uses include machine fabrication and assembly, setup and certification, and maintenance.
The kit measures straightness, perpendicularity, level and other parameters to an accuracy of 0.001" over a longitudinal travel of 150 ft. The measurement values can be used directly to make machine adjustments or uploaded to a PC for display and further computation and compensation. The solid aluminum laser and receiver housings are precision-engineered and anodized for wear resistance. The system is battery-operated, and a USB interface enables connection to a PC. Also included is the company's Pinpoint Capture software for data display, graphing and storage. All components fit in a carrying case for safe transportation.
See what you missed at IMTS!
Check out IMTSTV for segments about the show and what’s new in the world of manufacturing technology, then watch Shop Talk to get the Modern Machine Shop editors’ take on IMTS, the trends they’re seeing, and what’s coming next in your industry.
Learn More about IMTS
PINPOINT Laser Systems
Zones
  • Techspex
