Laser-Based ID/OD Measuring Instrument
The laser-based Labmaster universal measuring instrument is suited for gage calibration laboratories that need to precisely measure length, OD, ID, pitch diameter, linear displacement and thickness. According to the company, accuracy is maintained via a laser interferometer, a zero Abbé offset design and a large measuring table with center position, pitch and yaw controls. The computer-controlled precision air-bearing slide and gaging fingers reduce operator-influenced errors by maintaining constant force.
New Product From: 4/9/2009 Modern Machine Shop
The laser-based Labmaster universal measuring instrument is suited for gage calibration laboratories that need to precisely measure length, OD, ID, pitch diameter, linear displacement and thickness. According to the company, accuracy is maintained via a laser interferometer, a zero Abbé offset design and a large measuring table with center position, pitch and yaw controls. The computer-controlled precision air-bearing slide and gaging fingers reduce operator-influenced errors by maintaining constant force. It also minimizes wear and tear to both the measuring standards and the instrument.
Learn how to solve the metrology problems of tomorrow today. June 4-7, Las Vegas.
Marposs - Metrology equipment for improving productivity and reducing cost in manufacturing.
Advanced form, contour, surface and shaft metrology.
Precision is our business. Test us.
Zeiss
