Laser Marking System for High-Speed Applications
The compact Technifor F‐series laser solution from Gravotech is designed for permanent marking applications at a high rate of speed and in harsh working environments.
The compact Technifor F‐series laser solution from Gravotech is designed for permanent marking applications at a high rate of speed and in harsh working environments. The model is available in four power ranges: 10 W for surface coloring, 20 W for a more flexible solution, 30 W for high-speed marking and 50 W for deep marking/engraving.
