Laser Trackers with Mobile Device Control Enable Portablity
Westec 2017: Faro will exhibit its Vantage S and Vantage E laser trackers, which offer mobile device control and portability for efficiency and ease of use.
Faro will exhibit its Vantage S and Vantage E laser trackers, which offer mobile device control and portability for efficiency and ease of use in part and assembly inspection, machine installation, metrology-guided alignment, and reverse engineering. The company will also feature its RemoteControlsTM workflow, which is said to simplify operations such as target acquisition and accuracy checks, and eliminate locking onto the laser beam with simple gestures.
