Light Fixtures for Wet Environments
LDPI will highlight its LE300 high-performance LED lighting fixture, which is available in three wattages and is UL-listed for wet and marine outdoor locations.
LDPI will highlight its LE300 high-performance LED lighting fixture, which is available in three wattages and is UL-listed for wet and marine outdoor locations. The light fixture is IP66 and NEMA 4X rated, as well as Dark Sky Compliant. The 110-W version is tested at 40°C ambient temperature, while the 80- and 50-W versions are tested at 50°C ambient temperature. Available in pendant, ceiling, stanchion and yoke mounting, the light fixtures are designed for multipurpose use in a variety of exterior applications.
