Linear ID/OD Indicator Gage
For use on the shop floor, the Linear 100 is a high-precision, universal-length measuring instrument for rapid, high-accuracy internal and external measurements. With a direct measuring range of 2" (50 mm) and an application range of 4" (100 mm), the simple design makes it possible for the instrument to measure quickly and to adapt to new measurement tasks, the company says. For example, the instrument can be used to measure both lengths and diameters tasks such as measuring the dimension over two balls on gear ODs.
New Product From: 2/11/2009 Modern Machine Shop
Key features include an adjustable 3" × 3" (76 × 76 mm) table for precise measuring position adjustment of the part when measuring ODs, and a 4- to 40-oz (1 N to 11 N) adjustable measuring force that remains virtually constant over the entire measuring range. The 4" × 7.3" (100- × 185-mm) worktable can be used for ID measurement. The integrated measuring system is based on the Abbe principle (meaning, the measuring arm and reference are in line), which is said to eliminate cosine errors.
Also available is the 36 B ID/OD indicator gage, a versatile bench-mounted indicator gage that can measure IDs from 0.75" to 9" and ODs from 0.25" to 9.5". Other products include surface, contour and form measurement systems; shaft measurement instruments; precision length measurement systems; air gaging; electronic and mechanical gages; and hand-held measurement tools.
Mahr Federal Inc.
MMS Zones
Mahr Federal Inc.
Zones
Supplier Categories
Advanced form, contour, surface and shaft metrology.
Precision is our business. Test us.
Marposs - Metrology equipment for improving productivity and reducing cost in manufacturing.
Learn how to solve the metrology problems of tomorrow today. June 4-7, Las Vegas.
Loading the player ...
