Linear Rotary Motor Features Gearbox, Supports Higher Torque
LinMot will present a new addition to its PR01 series of linear rotary motors that includes a gearbox for torque requirements as high as 80 Nm.
New Product From: 7/7/2014 Modern Machine Shop, ,
LinMot will present a new addition to its PR01 series of linear rotary motors that includes a gearbox for torque requirements as high as 80 Nm. A planetary gear set with three specifiable transmission ratios enables tuning to the application and adaptation to the load's moment of inertia for precise and dynamic positioning. Depending on the application, linear and rotary motions can be actuated independently or synchronized by a higher-level NC controller. The integrated guide rails can support transverse loads at the full stroke of 150 mm, enabling dynamic and freely programmable motion of small dial tables with simultaneous rotational and vertical travel.
More technology – a lot more!
IMTS 2014 will be the year’s largest showcase of new product technologies and new process innovations. If you’re looking for machining, tooling, systems, software, solutions and more, you’ll find it at IMTS 2014.
Learn More about IMTS 2014
Register Now
for IMTS 2014
LinMot
Zones
  • Techspex
