Live Tools for Lathes
Designed to enhance the performance of a CNC lathe, the company offers a variety of live tools. These tools are designed to improve milling, drilling and tapping capabilities in turning operations. The company stocks a range of standardized live tools for CNC turning centers from major builders.
The live tool offering includes high-speed tooling, coolant feed-through tools, axial tools, radial tools, dual output radial tools and universal tools. Straight and offset units, modular quick-change systems and tapping quick-change holders are also available. Many models are lightweight and compact.
The live tools include optimized gears for smooth operation. Other advantages include lifetime lubrication of bearings, high torque transmission, internal coolant as much as 70 bar and length adjustment.
