Low-Weight, Carbon-Fiber Clamping Devices
The new carbon-fiber clamping devices for machining­ centers are as much as two-thirds lighter than the standard versions, but provide greater strength and rigidity with identical clamping force values, the company says.
New Product From: 8/10/2010 Modern Machine Shop
The new carbon-fiber clamping devices for machining­ centers are as much as two-thirds lighter than the standard versions, but provide greater strength and rigidity with identical clamping force values, the company says. The force-actuated TOPlus and the manually actuated Torok clamp versions enable faster spindle acceleration for faster machine cycle times. In addition, their low-weight reduces machine energy consumption. The lightweight version of the manual-actuation Manok plus stationary chuck is designed for implementation on milling machines and machining centers with low load weight. Its aluminum flange and carbon-fiber base structure offer a weight reduction of approximately two-thirds relative to the standard chuck version. Plus, the carbon-fiber model facilitates dynamic machining on five-axis machines in addition to offering lower energy consumption and smaller centrifugal forces.
Register Now for IMTS 2012
More technology – a lot more!
Learn More about IMTS 2012
Hainbuch America Workholding Technology
MMS Zones
Zones
Supplier Categories
There's more on workpiece holding and positioning in the Techspex Resource Center.
Self centering vise is a cost effective and universal workholding method for five sided machining.
