Okuma
Machining Center Extends Y-Axis Travel
Designed to meet the demands of moldmaking applications, Hurco’s VMX6030i vertical machining center provides more Y-axis travel in a footprint smaller than the company’s VMX64.
Designed to meet the demands of moldmaking applications, Hurco’s VMX6030i vertical machining center provides more Y-axis travel in a footprint smaller than the company’s VMX64. X-, Y- and Z-axis travels measure 60" × 30" × 24", respectively, and the machine also features a 12,000-rpm spindle and 40-tool swing-arm-type automatic toolchanger.
The worktable measures 66.14" × 30" and features Hurco’s UltiMotion system, said to reduce cycle times and improve surface finish. A dual-screen control console offers data block search, concurrent programming and DXF transfer features. The integrated Hurco control supports both ISO/EIA and conversational programming.
The machine is built on a heavy, ribbed cast iron frame. Pre-tensioned ballscrews are anchored at both ends for increased accuracy and rigidity. A 115-gallon coolant tank is standard. Options include through-spindle coolant, a thermal stabilization package, part probing and Renishaw tool probing.
Okuma
High Accuracy Linear Encoders
Gardner Business Intelligence
Okuma
