Machining Center Features Rapid-Rotation Table for Turning
Available from the Starrag Group, the five-axis Heckert HEC 800 X5 MT machining center features a rapid-rotation table for turning.
Available from the Starrag Group, the five-axis Heckert HEC 800 X5 MT machining center features a rapid-rotation table for turning. According to the company, the machine provides long-term workpiece accuracy and increased manufacturing reliability. The machining center is said to decrease costs as well as production times. The FANUC 3i CNC high-performance control system enables complex applications with many axes. The machine is designed to fully machine larger components made of corrosion- and heat-resistant materials.
When Too Many Customers Spoil the Part
Duo CNC used to take on as many customers as the shop could handle. But when growth stalled, a top-down audit by the company’s general manager revealed that its customer base was inhibiting growth — and causing the shop to be less efficient and productive.
