Machining Center for Fixtures
Mitsubishi EDM/Laser’s MCV 1000 machining center is a general-purpose machine for applications such as fixtures, mold base and secondary operations.
Vertical Lathe Executes Heavy-Duty, Long and Continuous Cutting
New VT1000EX Vertical Lathe from Okuma America Corp. possesses the capability to cut and machine difficult materials through, according to Okuma, its highly rigid, mechanical configuration, extreme thrust and torque.
