Magnetic Separator Enables Diversified Waste Disposal
The DMD magnetic disc depurator from Losma features rotating discs to eliminate magnetic particles without using consumable materials.
The DMD magnetic disc depurator from Losma features rotating discs to eliminate magnetic particles without using consumable materials. Dirty coolant flows through the system’s magnetic rotating disc group, which retains polluting particles. Then a blade scrapes the debris off the magnets and conveys it to the sludge chute to be deposited in the collecting tank. The clean oil can be pumped back to the machine tool or to an additional filtration process.
The unit’s structure can be changed from a fixed to adjustable chute by replacing the magnetic pack, which is composed of a tree, a magnet, separator disks and the related blades. According to Losma, the unit’s thicker separator discs increase magnetic power, and the reduced space they occupy enables adding more magnets into the magnetic pack for greater efficiency. Flow rates range from 50 to 500 L/min. for emulsion and from 25 to 250 L/Min. for neat oil. The system enables diversified disposal of magnetic waste and can be used in combination with other coolant depurators, the company says.
Rego-Fix Toolholding System Reduces Coolant Consumption
Oelheld Coolant Increases Metal Removal Rates
The odorless coolant is said to offer increased removal rates, lower electrode wear, excellent surface qualities, lower refill quantities and longevity to provide lower overall operating costs.
Unist's Electronic Control Regulates Lubricant Delivery
Unist’s Pulse R electronic control ties into the system control solenoid valve and takes the place of a pneumatic pulse generator timer or logic block.
