Magnifying Lamps Have Interchangeable Lenses
Aven’s ProVue Solas magnifying lamps increase flexibility with multiple interchangeable lenses in their durable housings
Aven’s ProVue Solas magnifying lamps increase flexibility with multiple interchangeable lenses in their durable housings. Users can enhance working distance, magnification or field of view without the need to have multiple lamps on hand. The lamp is available in two models. The Solas XL35 includes a 5-diopter lens (2.25× magnification) and can accommodate an optional 3-diopter lens (1.75× magnification). The Solas XL58 includes an 8-diopter lens (3× magnification), but also accommodates an optional 5-diopter lens.
The lamp has a fastening ring that is placed over the installed lens. It is designed to be easy to loosen and tighten when switching out lenses. Sixty ultra-bright white LEDs provide shadow-free illumination with a lifespan of 20,000 hours. The lamp head features micro touch buttons to adjust the brightness intensity of the LEDs. With a 36" covered spring-balanced arm, its range can meet most inspection needs without exposed springs or pinching hazards. A tension knob enables optimal lamp head positioning. The lamps come complete with a heavy-duty table clamp and power adapter.
