Manual Actuators for Gripping ID of Blind Holes
Mitee-Bite’s manual actuator is designed for the ID gripping of blind holes and various other applications.
Mitee-Bite’s manual actuator is designed for the ID gripping of blind holes and various other applications. The manual actuator can generate a pull-down force of more than 4,000 lbs and is capable of gripping bores ranging from 0.16" to 1.39" (4.1 to 35.3 mm) using standard ID clamps.
Mill and lathe versions are also available. The compact mill style can be mounted to hold the workpiece in both the vertical and horizontal planes to increase the functionality of fourth- and fifth-axis systems.
MMS Top Shops
The view from my shop.
