Metal Removal Fluids Support Work with Variety of Materials
Quaker Chemical offers a portfolio of metal removal emulsion technology, comprising the Quakercool 700 and 700 series, intended to serve the metalworking industry’s automotive/heavy equipment manufacturers and components producers that operate with diverse metallurgies.
Quaker Chemical offers a portfolio of metal removal emulsion technology, comprising the Quakercool 700 and 700 series, intended to serve the metalworking industry’s automotive/heavy equipment manufacturers and components producers that operate with diverse metallurgies. Quakercool 700 is designed for ferrous machining, while Quakercool 7000 is designed for aluminum and multi-metal machining.
According to the company, these products will benefit producers of metal components using individual machining cells or smaller central systems. The two series include six metal removal fluids combined, offering a selection of high-performance choices to suite specific needs for process efficiency.
These formulations are said to reduce the use of hazardous materials such as boron, formaldehyde and other substances of concern. The improved emulsion characteristics in several of the fluids directly influence plant metrics by reducing the chemical consumption or water use per part, while defending against traditional degrading materials like tramp oils. Benefits of both series include biostability against bacteria and fungi; flexibility for a range of operations including tapping and reaming; suitability for a range of materials including aluminum, stainless steel, steel, ductile cast iron, compacted graphite iron (CGI) and titanium alloys; no- to low-foam and high-emulsion stability over a range of water hardness; and low mist and odor.
STLE To Host Metalworking Fluid Management Program
STLE’s program is a two-and-a-half-day education program offering a comprehensive overview of metalworking fluid management.
Master Fluid Solutions Semisynthetic Coolant Inhibits Corrosion
Trim MicroSol 685XT is designed to provide enhanced corrosion inhibition on all ferrous and nonferrous metals.
