Metalworking Fluid Emulsion Extends Tool Life
Blaser Swisslube’s Blasocut BC935SW is said to provide high bio-chemical stability and increased sump life without the use of bactericides.
Blaser Swisslube’s Blasocut BC935SW is said to provide high bio-chemical stability and increased sump life without the use of bactericides. The chlorine-free fluid emulsion enables high cutting performance and long tool life in cast iron, steel, aluminum and exotic alloys. Its washing action and low misting properties promote machine and shop cleanliness, the company says. Formulated for use in water with a maximum hardness of 140 ppm, the fluid offers foam control in moderate to high coolant pressure applications.
Hennig Inc. Acquires Industrial Coolant Systems
ICS develops and field tests high-pressure coolant systems, coolant filtration systems and other machine tool solutions.
Master Fluid Solutions Semisynthetic Coolant Inhibits Corrosion
Trim MicroSol 685XT is designed to provide enhanced corrosion inhibition on all ferrous and nonferrous metals.
Managing Coolant with Skimmers, Refractometers and More
Bacteria-infected coolant harms machines and sickens machinists. Coolant management technologies like skimmers and automated systems counter this tendency.
