Metalworking Fluids Reduce Foaming at High Pressure
Qualichem will feature its Xtreme series of metalcutting and grinding fluids for high-pressure applications.
New Product From: 7/21/2014 Modern Machine Shop, ,
Qualichem will feature its Xtreme series of metalcutting and grinding fluids for high-pressure applications. To overcome problems associated with high-pressure delivery systems, the fluids are designed to minimize downtime for increased productivity, improved surface finish and part quality, extended tool life and reduced coolant usage. The formulation resists foaming, a common cause of inefficiency and machine downtime with high-pressure systems, the company says. The fluid series is designed to produce little to no foam in high-pressure applications with a variety of delivery systems.
See what you missed at IMTS 2014!
Check out IMTSTV for segments about the show and what’s new in the world of manufacturing technology, then watch Shop Talk to get the Modern Machine Shop editors’ take on IMTS, the trends they’re seeing, and what’s coming next in your industry.
Learn More about IMTS 2014
QualiChem Inc.
Zones
  • Techspex
