RoboDrill EcoPlus Offers Increased Machining Speed
FANUC RoboDrill EcoPlus offers a 21-tool capacity and increased speed through an optional 24,000 rpm spindle.
The FANUC RoboDrill EcoPlus offers 21-tool capacity and increased speed with an optional 24,000-rpm spindle. Two EcoPlus models are available, including one with a larger X-axis travel and table size.
The high-speed machining centers perform milling, drilling, tapping, deburring and chamfering, making them useful for taking over detail work from bigger, slower machines as well as performing secondary options, regardless of production volumes, the company says.
The EcoPlus D21MiB has a work area measuring 19.7" × 15.7" × 13" (500 × 400 × 330 mm). The EcoPlus D21LiB offers travels of 27.6" × 15.7" × 13" (700 × 400 × 330 mm). Standard features on both machines include a 14.75-hp (peak), 10,000- or 24,000-rpm direct-drive spindle with precision-enhancing thermal compensation and HRV control. The D21MiB has a table size of 25.6" × 15.7" (650 × 399 mm), while the D21LiB has a table size of 33.5" × 16.1" (951 × 409 mm).
Both machining centers provide rapid traverse rates ranging to 1,890 ipm (41 m/min), accelerations and decelerations ranging to 1.5 G, 0.9-sec. tool changes, rigid tapping to 5,000 rpm, and high-speed reverse tapping (up to 20 times faster than infeed).
Each machine is equipped with a FANUC 21i-B Nano CNC with simultaneous three-axis control. Options include high-speed indexers, a fourth axis, a signal lamp and robotic automation packages.
DN Solutions Introduces High-Productivity Vertical Machining Center
The SVM 5100L’s performance has been optimized to reduce the acceleration/deceleration times of the XYZ axes and spindle, reducing non-cutting time.
Additive/Subtractive Hybrid CNC Machine Tools Continue to Make Gains (Includes Video)
