Micro Lathe Offers Compact Footprint
The Grizzly Industrial G0745 Micro Metal lathe is designed for turning small workpieces.
The Grizzly Industrial G0745 Micro Metal lathe is designed for turning small workpieces. With 4 1/4" swing over bed and 6" distance between centers, the lathe is well-suited for jewelry, model-making and hobby applications.
The compact machine is built on a precision-ground cast iron bed and offers a footprint of 14" × 5 1/2", enabling benchtop use. The tailstock quill travel measures 7/8" and the cross-slide travel is 1 1/2". A single-phase, 110-V motor provides 150 W (1/5 hp), and the variable-speed spindle ranges from 100 to 3,800 rpm. The lathe is equipped with a 2" three-jaw chuck, a chuck safety shield, a tailstock dead center and a cross-slide mounted toolholder.
Zero-Adjustment Bar Pullers Simplify Turning Automation
Spring-loaded grippers and adjustable programming are enabling bar pullers to fulfill their promise to save time and money in CNC turning automation.
Kaast Machine Tools Updates Dual-Spindle Lathe
