Milling Cutter for Roughing, Finishing Cast Iron
Sumitomo Electric Carbide says its SumiMill Goalmill milling cutter accurately finishes cast iron.
The cutters are available for roughing (<50Rz) semi-finishing (<18Rz) and finishing (<12.5Rz). Left-handed cutters are made to order.
Widia Introduces Solid End Mill for Shoulder and Side Milling
Grooving Attachment Streamlines Operation by 75%
A grooving attachment enabled Keselowski Advanced Manufacturing to reduce cycle times by over 45 minutes on a high-value, high-nickel part feature.
