Milling Cutters Reduce Need for Polishing in Medical Machining
Seco Tools has introduced a cutting tool line designed for machining medical knee implants.
Seco Tools has introduced a cutting tool line designed for machining medical knee implants. The Jabro range of solid carbide cutters for high-speed medical machining and other aggressive milling strategies can shorten cycle times on knee implants by as much as 50 percent, according to the company.
The tools’ continuous grades and coatings are said to reduce or eliminate the need for polishing or fine finishing operations. These features also promote process stability and long tool life, according to the company.
The product line includes nine advanced geometries and 39 tools, most of which are part of the Jabro Tornado high-speed cutting family. Each geometry is designed for particular applications in the machining of tibial tray and femoral knee implant components. Because these tools are designed to machine cobalt-chrome (CoCr) and 3D-printed Ti6Al4V ISO-S12 parts, they can also improve machine performance for other medical implant components, including hip replacements and bone plates, according to the company.
Five-Axis Changes Weldments Into Monolithic One-Piece Parts
Moving from welding to five-axis machining enabled Barbco to redesign its weldments as monolithic one-piece parts with improved strength and repeatability.
