Milling Postprocessor Supports Sinumerik-Controlled Machines
Mastercam has released a four-axis milling post processor that is said to enable productivity on Sinumerik-controlled machine tools.
Mastercam has released a four-axis milling postprocessor that is said to promote productivity on Sinumerik-controlled machine tools. This postprocessor supports Sinumerik 840D sl and 828D CNCs from Siemens.
The postprocessor features CYCLE 832 support for high-speed settings, now including the latest Top Surface functionality; drill cycles (CYCLES 82 through 86 and 840) with full four-axis support; WORKPIECE output for Graphical simulation, including rotary-axis blank orientations; tool call as tool name or tool number; a TOFFR option; Siemens’ four-axis application guide; an optimized multi-axis tool path using the FGROUP and FGREF commands; and streamlined program editing with the GROUPS functionality.
Improve Machining Efficiency Through Digital Twin Simulation
Full simulation of a machining cycle using digital twins can not only identify crashes before they happen, but provide insights that enable the user to reduce cycle times.
Building A Powerful Bridge from the CAM Programmer to the Shop Floor Operator
SolidCAM for Operators provides a powerful bridge from CAM programming to the shop floor to best streamline the machine shop process with its CAM part simulation. It provides a clear picture to the operator for setup and prove-out, enables minor G-Code changes and avoids crashes, broken tools and scrapped parts.
